How to soldering the Li-ion battery
LAOADAM
Joined Nov 21, 2018
956
The battery in my GPS is exhausted,that is a T300-3 720 mAH, the one I have in hand is a MO-V220-C350 with 3 copper poles, how to soldering that? I mean what is positive and negative pole and detection line?
Adam
Audioguru again
Joined Oct 21, 2019
6,826
Batteries are spot-welded that does not heat their insides. Soldering heats their insides that might cause a Lithium explosion and fire.
Some Ni-Cad batteries can be soldered because their chemicals do not explode and burn.
Using a battery with a wrong kind of polarity and sensor is asking for trouble. Use the correct battery.
LAOADAM
Joined Nov 21, 2018
956
Thanks.
I ordered one.
