I assume ADS is a simulator. I use LTspice and it should be able to do what you want so I assume ADS can, as well.
It is important to have a good model of the diode to trust the results of the simulation. Use the test circuit from the diode's data sheet. If there is no test circuit then find a application note from a company that makes switching diodes.
