I am trying to simulate the effect of aging in the back-to-back inverters (SRAM PUF). I want to see the starting up of the back-to-back inverter's start-up voltage with transistor aging effect, wherein in one case the output initial from the 2 inverters is 1 0 and in another case, the output case will be 0 1.
How to do this in hspice. I know a little about the MOSRA test, but I am not sure how to use that to get the intended aging effect.
Following is a back-to-back inverter hspice netlist. but the output is always same with the simulation. How to flip the output with aging simulation. Any help is appreciated.
* PUF
vdd vdd gnd dc 1v
Mp1 out2 out1 vdd vdd pmos w= 90nm l= 45nm
Mn1 out2 out gnd gnd nmos w=45nm l= 45nm
Mp2 out1 out2 vdd vdd pmos w= 90nm l= 45nm
Mn2 out1 out2 gnd gnd nmos w=45nm l= 45nm
*transient analysis
.model p1_ra mosra level=1
+tit0 = 5e-8 titfd = 7.5e-10 tittd = 1.45e-20
+tn = 0.25
.appendmodel p1_ra mosra p1 pmos
.mosra reltotaltime= 1e8
.tran .1ps 5ns
.options post
.print V(out2) V(out1)
* PTM Low Power 45nm Metal Gate / High-K / Strained-Si
* nominal Vdd = 1.1V
.model nmos nmos level = 54
+version = 4.0 binunit = 1 paramchk= 1 mobmod = 0
+capmod = 2 igcmod = 1 igbmod = 1 geomod = 1
+diomod = 1 rdsmod = 0 rbodymod= 1 rgatemod= 1
+permod = 1 acnqsmod= 0 trnqsmod= 0
+tnom = 27 toxe = 1.8e-009 toxp = 1.5e-009 toxm = 1.8e-009
+dtox = 3e-010 epsrox = 3.9 wint = 5e-009 lint = 0
+ll = 0 wl = 0 lln = 1 wln = 1
+lw = 0 ww = 0 lwn = 1 wwn = 1
+lwl = 0 wwl = 0 xpart = 0 toxref = 1.8e-009
+vth0 = 0.62261 k1 = 0.4 k2 = 0 k3 = 0
+k3b = 0 w0 = 2.5e-006 dvt0 = 1 dvt1 = 2
+dvt2 = 0 dvt0w = 0 dvt1w = 0 dvt2w = 0
+dsub = 0.1 minv = 0.05 voffl = 0 dvtp0 = 1e-010
+dvtp1 = 0.1 lpe0 = 0 lpeb = 0 xj = 1.4e-008
+ngate = 1e+023 ndep = 3.24e+018 nsd = 2e+020 phin = 0
+cdsc = 0 cdscb = 0 cdscd = 0 cit = 0
+voff = -0.13 nfactor = 1.6 eta0 = 0.0125 etab = 0
+vfb = -0.55 u0 = 0.049 ua = 6e-010 ub = 1.2e-018
+uc = 0 vsat = 130000 a0 = 1 ags = 0
+a1 = 0 a2 = 1 b0 = 0 b1 = 0
+keta = 0.04 dwg = 0 dwb = 0 pclm = 0.02
+pdiblc1 = 0.001 pdiblc2 = 0.001 pdiblcb = -0.005 drout = 0.5
+pvag = 1e-020 delta = 0.01 pscbe1 = 8.14e+008 pscbe2 = 1e-007
+fprout = 0.2 pdits = 0.08 pditsd = 0.23 pditsl = 2300000
+rsh = 5 rdsw = 210 rsw = 80 rdw = 80
+rdswmin = 0 rdwmin = 0 rswmin = 0 prwg = 0
+prwb = 0 wr = 1 alpha0 = 0.074 alpha1 = 0.005
+beta0 = 30 agidl = 0.0002 bgidl = 2.1e+009 cgidl = 0.0002
+egidl = 0.8 aigbacc = 0.012 bigbacc = 0.0028 cigbacc = 0.002
+nigbacc = 1 aigbinv = 0.014 bigbinv = 0.004 cigbinv = 0.004
+eigbinv = 1.1 nigbinv = 3 aigc = 0.015211 bigc = 0.0027432
+cigc = 0.002 aigsd = 0.015211 bigsd = 0.0027432 cigsd = 0.002
+nigc = 1 poxedge = 1 pigcd = 1 ntox = 1
+xrcrg1 = 12 xrcrg2 = 5
+cgso = 1.1e-010 cgdo = 1.1e-010 cgbo = 2.56e-011 cgdl = 2.653e-010
+cgsl = 2.653e-010 ckappas = 0.03 ckappad = 0.03 acde = 1
+moin = 15 noff = 0.9 voffcv = 0.02
+kt1 = -0.11 kt1l = 0 kt2 = 0.022 ute = -1.5
+ua1 = 4.31e-009 ub1 = 7.61e-018 uc1 = -5.6e-011 prt = 0
+at = 33000
+fnoimod = 1 tnoimod = 0
+jss = 0.0001 jsws = 1e-011 jswgs = 1e-010 njs = 1
+ijthsfwd= 0.01 ijthsrev= 0.001 bvs = 10 xjbvs = 1
+jsd = 0.0001 jswd = 1e-011 jswgd = 1e-010 njd = 1
+ijthdfwd= 0.01 ijthdrev= 0.001 bvd = 10 xjbvd = 1
+pbs = 1 cjs = 0.0005 mjs = 0.5 pbsws = 1
+cjsws = 5e-010 mjsws = 0.33 pbswgs = 1 cjswgs = 3e-010
+mjswgs = 0.33 pbd = 1 cjd = 0.0005 mjd = 0.5
+pbswd = 1 cjswd = 5e-010 mjswd = 0.33 pbswgd = 1
+cjswgd = 5e-010 mjswgd = 0.33 tpb = 0.005 tcj = 0.001
+tpbsw = 0.005 tcjsw = 0.001 tpbswg = 0.005 tcjswg = 0.001
+xtis = 3 xtid = 3
+dmcg = 0 dmci = 0 dmdg = 0 dmcgt = 0
+dwj = 0 xgw = 0 xgl = 0
+rshg = 0.4 gbmin = 1e-010 rbpb = 5 rbpd = 15
+rbps = 15 rbdb = 15 rbsb = 15 ngcon = 1
.model pmos pmos level = 54
+tnom = 27 toxe = 1.82e-009 toxp = 1.5e-009 toxm = 1.82e-009
+dtox = 3.2e-010 epsrox = 3.9 wint = 5e-009 lint = 0
+lwl = 0 wwl = 0 xpart = 0 toxref = 1.82e-009
+vth0 = -0.587 k1 = 0.4 k2 = -0.01 k3 = 0
+dvt2 = -0.032 dvt0w = 0 dvt1w = 0 dvt2w = 0
+dsub = 0.1 minv = 0.05 voffl = 0 dvtp0 = 1e-011
+dvtp1 = 0.05 lpe0 = 0 lpeb = 0 xj = 1.4e-008
+ngate = 1e+023 ndep = 2.44e+018 nsd = 2e+020 phin = 0
+voff = -0.126 nfactor = 1.8 eta0 = 0.0125 etab = 0
+vfb = 0.55 u0 = 0.021 ua = 2e-009 ub = 5e-019
+uc = 0 vsat = 90000 a0 = 1 ags = 1e-020
+keta = -0.047 dwg = 0 dwb = 0 pclm = 0.12
+pdiblc1 = 0.001 pdiblc2 = 0.001 pdiblcb = 3.4e-008 drout = 0.56
+pvag = 1e-020 delta = 0.01 pscbe1 = 8.14e+008 pscbe2 = 9.58e-007
+rsh = 5 rdsw = 250 rsw = 75 rdw = 75
+eigbinv = 1.1 nigbinv = 3 aigc = 0.0097 bigc = 0.00125
+cigc = 0.0008 aigsd = 0.0097 bigsd = 0.00125 cigsd = 0.0008
+at = 33000
+xtis = 3 xtid = 3
.end
* PUF
vdd vdd gnd dc 1v
*transient analysis
+tn = 0.25
.tran .1ps 5ns
.options post
+at = 33000
+xtis = 3 xtid = 3
+at = 33000
+xtis = 3 xtid = 3
.end
