- Joined Jan 23, 2018
- 28,212
Certainly Irving offers a very good suggestion, certainly worth investigating with your meter. AND, that would be an excellent connection for an isolated voltage sensing scheme. A big "Thank You" to Irving for a very good suggestion.No, I meant what I said. HZ/HZ is the wiring to the bell push button at the front door to the block (and maybe outside the apartment door too). Its a simple switch contact. For that to work there must be a voltage across the contacts, or between one of them and GND. Typically this will be 3v or 5v but might be higher. The assumption is that is derived from the 30v and therefore is a safe proxy for it. The downside is that it will also vanish if someone presses the bell push. However since that's a relatively short process, a few seconds maybe, we can distinguish between a press of the door bell and a power cut by simply waiting to see if it lasts longer than, say, 30 seconds.
So take your voltmeter and measure across the HZ contacts and also between each HZ contact and GND, record what voltages you get. Then get someone to press your door bell and see what happens to those voltages. Finally, if you can, validate they also vanish when the 30v vanishes.
