How to run .cir LTspice file
MOUMNI
Joined May 7, 2021
I am a new in LTspice simulations and I download from Mouser a .CIR LTspice file of SN74LVC1G08 inverter gate and when I run it in LTspice a message pop out "NO analysis request found", I am looking for a simple SN74LVC1G08 gate model.
Thank you for help and any instruction.
38,767
So you need to specify a circuit analysis (likely Transient as below):
And you need to have the gate connected to power and signal(s).
atferrari
Joined Jan 6, 2004
5,028
If running a simulation is what you need to learn, get one of the tutorials by Simon Bramble.
Pay attention to the initial steps.
eetech00
Joined Jun 8, 2013
4,724
The file you've posted is a spice subckt describing the behavior of a SN74LVC1G08 AND gate. LTspice needs a spice circuit desciption and stimulus definition in order to run a simulation.
So...
1. You can add spice statements in the file to define a schematic, stimulus, and simulation requirements. Then run in LTspice.
-or-
2. You can create an AND gate symbol, create a schematic, and simulate in LTspice.
Item 2 is the best choice for a beginner.
Papabravo
Joined Feb 24, 2006
22,111
The 74LVC1G08 is a 2-input AND gate, NOT an inverter. Your file is a subcircuit file that calls a lower level primitive defined in the file. You need to have a top level schematic that calls the subcircuit, provides inputs and supply voltage and monitors the output.
