I want to read a voltage pattern, written in an abcd.txt file, using "pwl" we use it as a voltage source to a node ( say n1) in ltspice to see an output of a node ( say n2) in simulation. Again, I need to write another pattern in the same abcd.txt file, read it with pwl and observe output at node2.
Suppose, we repeat this 1000 times. How do I go about it?
