MrSoftware
- Joined Oct 29, 2013
- 2,280
OK, if you were in the US I was going to offer to swap it for you. Remove the battery, put your multi-meter in continuity mode (beeps when probes touched together) and figure out which of those metal pads where the black button USED to be connect to which pins on the button. That will tell you which pins you need to connect your new button to.
