Hi, I'd like to take the output from a hall effect sensor and reduce the rate of the signal.
The application: A magnetic sensor, on my bicycle, is used to indicate the speed of the bike. The signal is derived from the rate of wheel revolutions. I'd like to convert that rate, by modifying the signal so that it reads a lower rate.
Whilst the true signal may be 100 pulses per minute, I'd like the signal to suggest only 75 ppm.
What would I need to introduce into the signal wire to achieve this outcome?
Thanks wizards!
Thanks wizards!
