how to reduce smps noise
kavyaranibhee
Joined Oct 26, 2017
9
thank you
Also in some datasheets there are optional filters given in the example schematics.
Here is one taken from the LM2596 datasheet:
i connected dc to dc coverter lm2596 for that also am getting noise.... what to do?
noise is 800mv.
i given input for dc to dc converter from linear regulated power supply then also am getting noise....
bertus
Joined Apr 5, 2008
22,921
I don't quite understand you.
How are things connected?
Can you post a diagram?
Did you implement the extra filter given?
kavyaranibhee
Joined Oct 26, 2017
9
as u told lm2596 buck regulator like that i have lm2596 dc to dc converter i connected that to the smps output.....
i have lm2596 dc to dc converter i connected that to the output of smps.....
in this image i connected lm2596 dc to dc converter through power supply..
for that am getting peak to peak voltage 800mv how to reduce it?
bertus
Joined Apr 5, 2008
22,921
A smps is a switching powersupply that will give you much more noise than a linear powersupply.
If you feed either of them to a DC-DC converter, you will introduce noise again, as a DC-DC converter is most likely a switching powersupply too.
kavyaranibhee
Joined Oct 26, 2017
9
thank you
kavyaranibhee
Joined Oct 26, 2017
9
i was using smps for the given block diagram am getting noise i have to reduce noise..
bertus
Joined Apr 5, 2008
22,921
You have three times an 24 Volts supply in your drawing.
Are those all from the 24 Volts smps?
Is 800 mV disturbing the 24 Volts valve?
