We have a Hubsan quadcopter/drone that has 4 brushed motors (BDC) and we want replace them with Brushless Motors (BLDC).
One of us that is more advanced at this conversion project has connected the 4 ESC (necessary for (BLDC motors) to the correspondent Mosfet. The “signal wire” of our ESC is a twisted par with white and a black wires, so the PWM Signal/White wire is connected to the Gate and the Signal/Ground to Source of Mosfet.
With these connections the BLDC are working, so the quadcopter is flying! The problem is for that happen we must keep the brushed motors connected to the Flight Controller/Receiver (integrated) and spinning at same time as BLDC (see picture) ! Each Brushed M. is connected by two wires to the correspondent + and - of the FC/Receiver!
I put the question in another forum if Resistors could replace the, now, useless brushed motors, but the answer was no, if I understood well the explanation, so I must follow another track that is decrease RPM.
Once the Hubsan Flight Controller is proprietary and no documentation is available, I cannot control the speed by traditional methods, so I want to add one or more components to reduce "artificially" the RPM of these motors and with this minimize the weakness of brushed motors at quadcopters, the main reason for our conversion project (we must replace the brushed motors regularly).
Note - these brushed motors draw 1V & 0.05A at idle and 6.5V & 1A at full throttle!
because they die)
because they die)
