How to prevent BJT from saturation in the case below
YoGMan
Joined Sep 20, 2017
76
Hello guys , How do I convert a 50mV signal to volts without any clipping. My design is as shown below.
Here is how I proceeded
1)I DC biased my amplifier so that Vce is 9.3 V
2) I assumed a 2mA collector current at Q point
3) The values of Rc and Re were then calculated
4) From the resulting voltage Ve, Vb= Ve+0.6 V and the ratio of resistor R1 and R2 was calculated.
The only problem is that the amplifier goes to saturation , I want to input signals of around 50mV and get an output around 5V pk-pk.How can I modify my circuit?
Bordodynov
Joined May 20, 2015
3,428
Usually in a circuit with a common emitter, emitter resistors are used to stabilize (losing voltage!) And an additional capacitor has to be used.I’m promoting a true scheme with a common emitter on this forum.Also, to stabilize the regime and gain, I use parallel negative feedback (sequential feedback is usually used in schools).
The usual version of the scheme (in our case, I cheated and upgraded the scheme):
Here is how I choose resistors:
The voltage at the collector I take about half the supply voltage.
1. For a collector, I choose a resistor of 5-10 times smaller than the load.
This is to get almost maximum output amplitude and lower voltage gain losses.
2. For a base-collector resistor, I take a resistor 10-20 times the collector (when using transistors with a higher current gain,
you can increase the value).
3. To calculate the resistor between the base and the emitter, calculate the current through the base resistor and subtract the base
current from it.To calculate the desired resistor, it is necessary to know the base-emitter voltage at the selected current.In our case, 0.71B.At lower currents less.We divide the voltage by the current and get the nominal value.With this resistor (its size) we adjust the output voltage at the collector.
4. Choose a negative feedback resistor.Determine the upper limit of the resistor.The required gain is 5V / 50mV = 100 ==>
Rbe <20kOhm / 100 = 200.Amplification of a transistor (not an amplifier) over voltage is approximately 9V * 30 = 270 (9V is the voltage across the collector resistor).There are also losses on the Rbe resistor and the input resistance of the transistor. We choose about 2 times less and check.If you need a small gain, the gain is approximately equal to the ratio of the base and the desired resistor.
YoGMan
Joined Sep 20, 2017
76
Yes. Remove that capacitor.
The cap is to bring the high frequency cutoff response down to 5Khz , I managed to play with the values to get both gain and frequency response I need. But a trade off has to be made as high gain will give poor freq response
Bordodynov
Joined May 20, 2015
3,428
You can certainly more accurately calculate the gain.But then you have to use the equivalent circuit of the transistor in conjunction with the circuit.But you can use Spice!
YoGMan
Joined Sep 20, 2017
76
Thank you :) I will study the circuit in more detail. I need to add one more stage to the 2 stages i made to amplify 5mv from microphone to 50mV.I will re upload the final 3 stages in a moment ;)Hope it works as expected
