How to navigate a maze? What should I use?
John A Bonilla
Joined Mar 11, 2017
92
So I have my robot base which currently looks like this:
This allows me to move in any direction as the wheels are a special type. The extra part on the bottom was used to do something else, and holds no significance right now. To drive it I am currently using an Arduino Mega, an Adafruit Motor Shield, and three vex motors. I am limited in my budget so I need to come up with a way to navigate it through the maze, other than making it remote controlled. This means that stuff like a lidar sensor is out of the question. GPS is definitely not possible as the maze overall is only 16ft x 16ft. I currently have access to an optical mouse to measure the distance the robot has moved. I also have access to ultrasonic sensors. I might be able to use the two in unison to navigate it, but I was wondering if anyone had any ideas as to make this simpler for me. If not then I'll just use that method. Thank you for taking the time to read this and I look forward to your suggestions!
Regards,
John B.
John A Bonilla
Joined Mar 11, 2017
92
-live wire-
Joined Dec 22, 2017
959
I do not think that there are better sensors that are affordable. But you could make a good map of the surroundings with some ultra-sonic sensors, and they are probably your best bet. Also, a lot depends on the program, so make sure to program it well.
John A Bonilla
Joined Mar 11, 2017
92
Thank you very much, I'll do that!
dl324
Joined Mar 30, 2015
18,449
It's for a competition and I'm trying to learn more so that I can work on it. May I ask why is it important?
It's school work for which you will receive a grade, someone else doing the work for you is cheating.
If you're supposed to learn how to detect obstacles, we shouldn't just give tell you how.
If you're supposed to come up with an algorithm for negotiating the maze, we shouldn't just give you one.
John A Bonilla
Joined Mar 11, 2017
92
Oh that's what you meant, no lol that's not the case, it's a competition trying to navigate a maze. It's not a grade, it's actually a club that participates in this event. I'm not asking you to tell me what surgically to do, but to just give me suggestions of any other ways possible. Then I'll look into it and do it myself. I hope that clears things up a little
35,033
If you always took a left turn you will eventually make it out.
Works also if you always take a right turn.
If you can do two trials, you can save a database and then optimize your run on the third run.
WBahn
Joined Mar 31, 2012
33,080
That only works on mazes in which both the entrance and exit are on the outer rim. Many maze competitions place either the start or the goal at the center of the maze specifically to defeat this approach.
John A Bonilla
Joined Mar 11, 2017
92
I could do that, however the only issue is that I have to make two stops along the way, so just moving against a single direction will not work.
Luckily for me this is not the case, the robot starts and ends outside of the overall maze. However as I mentioned this tactic will still be futile as I have to stop and change direction.
