How to measure frequency of generator ?
Rufus Chucklebutty
Joined Mar 23, 2019
70
I have a capacitor regulated 50 hz ( 3 kw) generator and need to set the frequency but I'm not getting any readings I can make sense of, at 230 v my multimeter says 1.3 khz and my plug in my plug in meter says 210 hz.
I replaced the capacitor with a used non OEM one of the same value .
I haven't got a tacho.
KeithWalker
Joined Jul 10, 2017
3,618
What test equipment do you have? You are probably overdriving the input to your frequency counter. Check its input spec. You may need to use a resistive attenuator or a transformer to reduce the voltage enough to get accurate readings.
If you have an oscilloscope you can use the mains frequency as a reference and adjust the generator using Lissajous figures.
Rufus Chucklebutty
Joined Mar 23, 2019
70
I've got a kill-o-watt meter and a multimeter
