How to measure AMP battery
22,098
when i measure the current using mulltimetr not gev me Fixed number
Different numbers and then disappear
Then Ohms law tells me that you do not have a FIXED and CONSTANT load. An ammeter is a very low resistance, and could be damaged by doing what you did. Pick a resistor that will give you say 50 milliamps.
3.7 Volts / .050 Amperes ≈ 75 Ohms
The ammeter in series with the resistor goes across the battery terminals. Just to be extra safe estimate the power dissipated by the resistor as
(.050 Amperes)^2 * 75 Ohms ≈ 187.5 milliwats
So a quarter watt resistor will get warm but not explode.
MikeML
5,444
I'm guessing that size is about 1500mAh.
If 20Ω (180mA load current) pulls that battery down immediately, then it is totally discharged, and needs charging before you do any more tests.
sendbad
Joined Jan 8, 2015
43
i will do it
