If I'm correct... It's electromechanical technique but I need to give it pulse for ON and OFF.Sounds like what you want is an "alternate action" pushbutton. The first push sets it to one state and the next push sets it back to the other state. Same thing. Just do a search for "alternate action bushbutton"
I wondered the same thing. A Google image search brings up some fairly nasty George Bush lapel buttons.(what's a bushbutton?)
Ken
Yes, We can use transistors...Why can't you use an alternate action pushbutton switch, as recommended by john-campbell?
If you need it to be actuated by a pulse, and you don't want to use ICs, can you use transistors?
Is your input a switch, a pulse, or...Yes, We can use transistors...
It's a pulse.Is your input a switch, a pulse, or...![]()
Whatever you want but it should be pulse.What is the source of the pulse? Voltage? Polarity? Pulse width?
Ken
Now that's license.Whatever you want but it should be pulse.
You're with the license but It's prohibited to use such mechanical control... Let's say the pulse is of electrical type... and this circuit should behave as the JK Latch... but without using ICs... can be used transistors and passive frens....Now that's license.Since the pulse can be anything...I choose "momentary, dry-contact switch closure"!
Not my circuit, but I always thought it was a novel idea.
Ken
