How to make 3 pins power ( V+ GND V- ) from 12v Battery ?
Tùng Sơn Lê
Joined Jun 21, 2017
Hello everyone,
I am doing a DIY speaker which i want to have a micro , a guitar input with a bluetooth amplifier ( TDA7492 Bluetooth ) . Everything was ok until i met the problem about power for opamp to gain for micro & guitar , it requires V+ GND V- , and i just have the 12v battery for TDA 7492 .
So how can i make 3 pins power ( V+ GND V- ) from 12v Baterry ?
Thank you very much ,
Tungggg
EM Fields
Joined Jun 8, 2016
578
Hello everyone,
Tungggg
Use an isolated DC to DC converter to generate the negative voltage and tie its positive voltage to battery minus/ground.
JUNELER
Joined Jul 13, 2015
183
Im trying to find an IC for your needs but i cant find. Another solution is to create a circuit using a transformer.
Primary side is input like 110vac or 220vac as you like. On the secondary side a 12vac o 12 vac wiring.Center tap secondary.
Rectify a positive 12v and a rectify negative 12v if you know how to do it . Or else you can buy a ready made available power supply with an
output of your needs.
Alec_t
Joined Sep 17, 2013
15,171
Since the -ve supply is used only for the opamp, instead of a true GND you can use a virtual ground .
The 0V and +V rails are then treated as -V and +V respectively, avoiding the need to generate a true negative supply. The opamp's signal input and output would each require an AC coupling capacitor.
