How to know SMD components real references?
Tonyr1084
Joined Sep 24, 2015
9,744
Sometimes a part is too small to put its identification on it. Manufacturers resort to an Alpha/Numeric code (such as your BUA or the HRFBS) If you know the manufacturer you can visit their website and look up the codes. But each manufacturer can have a different set of codes for a component.
SLK001
Joined Nov 29, 2011
1,549
If you don't know what they are to start with, finding out what they are is very difficult. Sometimes it is helpful to sketch out a schematic with the part in it to see if you can at least determine its function.
dl324
Joined Mar 30, 2015
18,465
Welcome to AAC!
does any one know how to determine a components like in these photos?
There are various references on the internet that cross reference SMD marking codes to manufacturer part numbers. Unfortunately, manufacturers are free to use any codes they want and multiple manufacturers can use the same code for different devices.
Here's one. https://www.electroschematics.com/wp-content/uploads/2013/04/SMD-code-book.pdf
It would be best if you posted the markings. I can't tell if the markings that look like 'B' might actually be '8'.
