If this is homework, you should post in the Homework Help forum. In any other forum, someone may just give you the answer and that could be considered cheating and result in a failing grade.i was not explained anything by the lecturer. So i am just learning everything by myself. It is an assignment and i am not being able to move further.
Then we're going to need to be able to see the logic gates by the decoders.this timer is supposed to start from 00:00 till 59:59
No we learnt only to connect a simple lighting bulb, and save it. We were then given this assignment. It has been 2 whole weeks i am bent on trying to add a pause and reset but i cant. I am trying a way to post my work in the correct way. As i told you before, i am very new in digital electroncs.Still unreadable. Did you learn to check your work in school?
Print to a PDF.
When is the assignment due and what are your ideas for adding pause and reset?It has been 2 whole weeks i am bent on trying to add a pause and reset but i cant.
What do you think is causing that behavior?note that the reset switch only displays ZERO, but it doesnot actually reset the timer; the timer is running meanwhile in the background.
No need to worry. It's a simple problem; the slow part will be guiding you to a solution. Next time, don't wait so long to ask for help; preferably from your instructor or classmates.Deadline is till 4th jan 2016.. damn close huh?? Feeling desperate..
Now you need to post what you've tried and why it didn't work.For the reset, i've read somewhere that i will have to connect the reset pins of the 4510 BCD to ground or something, i tried it, but it went awry.
by Don Wilcher
