How to Indentify terminals of a relay
beenthere
Joined Apr 20, 2004
15,819
It's hard to give a good reply without any idea of the relay in question. If you have a number on it, then the manufacturer should have the information.
Do you have any idea of the type and voltage on the coil?
lpfan
Joined Feb 8, 2007
3
Yes I do hv the info on it. It is a 6v d.c. 400 ohms , 150mA, single pole double throw switch. what i want to know is tht how to identify which terminal is the coil terminal and which are the normally closed and normally open ones? Thx fr replying to my thread:)
beenthere
Joined Apr 20, 2004
15,819
Two pairs of terminals will have some continuity between them. One pair will read 400 ohms - that's the coil. The other two will read 0 ohms - that's the common and NC (normally closed) contact. Put 6 volts on the coil, and the common terminal and the one that checked open before will show 0 ohms (the NO, or normally open terminal).
