(de something?????? cannot remember the name of this water) water would help to mantain battery life where it would not get hot ******but not regular drinking water**** it has clorine in it. also you can clean out with allum and magnesium if battery gives problem (you tube) uses this to regenerate a battery $5.00 repair . as far as maintance on heavy equipment if it does not perform, it is gone and another is replaced. i was a service man on hvy eqthanks for your replies.what i mean is a 12 volt battery used in the heavy equipments or heavy vehicals has to be maintained for its reliability.what actions can be taken to maintain that?please list out.
8 years later! what took you so long?(de something?????? cannot remember the name of this water) water would help to mantain battery life where it would not get hot ******but not regular drinking water**** it has clorine in it. also you can clean out with allum and magnesium if battery gives problem (you tube) uses this to regenerate a battery $5.00 repair . as far as maintance on heavy equipment if it does not perform, it is gone and another is replaced. i was a service man on hvy eq
P.S. I just found this site today.check (youtube) (5.00 battery repair ) it can be used with the allum and magnisum and it will work. I would use this to clean battery and wash out many times . Put in new acid and water this will rejuvinate the battery.
