How to increase my 555 output current.
Jose Espigares Perez
Joined Jun 25, 2017
21
Hi everybody,
I have the attached circuit, and it works perfectly (I have a 85% Duty signal) but I need more current, 555 timer output current is not enough for me, so I need to install another circuit to amplify my signal.
Anybody knows how can I make it?
Thanks a lot in advance,
Bye!
wayneh
Joined Sep 9, 2010
18,169
As long as your current need is less than 50A or so, your solution is likely just a single MOSFET as a switch. But you need to specify whether you are sinking or sourcing current, or both, the switching frequency, the current, the voltage, and any other details that might be important (like operating at high ambient temperatures or whatever).
ian field
Joined Oct 27, 2012
6,536
Hi everybody,
Bye!
Since you are using pin 3 to drive the CR timing, you can spare the in phase drive at pin 7. Just give pin 7 a 2k2 pull up resistor and drive a MOSFET. If you can't have that phase inversion; make that a small signal phase inverter and add a second MOSFET that can handle the current you need.
