How to improve the Emitter−Base Voltage for NPN BJT
Nick Long
Joined May 12, 2020
75
Below is the maximum ratings for 2N3904 NPN BJT. As you can see the maximal Emitter-Base voltage is 6 V. I have checked many other BJT datasheets which all show that this voltage is around this value. But in my circuit the Emitter-Base voltage of NPN BJT will be over 6 V which causes the operation is not normal. I konw by connecting a diode to the emitter of the BJT in series can improve the problem. Is there another better method? Thanks in advance!
35,299
This is the maximum reverse bias voltage allowed.
The forward voltage will be around 0.7V. You need to limit the current, not the voltage.
KeithWalker
Joined Jul 10, 2017
3,628
In you circuit, the emitter/base voltage should be measured from the base to the emitter, not from the base to circuit common, and will be around 0.7V,
Alec_t
Joined Sep 17, 2013
15,168
You can connect a diode in series with the base (or the emitter, as you'r aware) to withstand a high reverse voltage.
Nick Long
Joined May 12, 2020
75
The reverse Emitter-Base Voltage of T3 or the Base-Emitter Voltage of T4 will be over 6 V if the input voltage is large.
ronsimpson
Joined Oct 7, 2019
4,894
After reading the paper on this circuit, I think it does not help much.
I think adding a "power factor correction" circuit will do a better job.
We can see that with out extra parts the power coming from the Piezo only happens at the peaks of the cycle. Pulling power 90% of the time (by theory) should allow for more power. I think, but do not know, that in the case of Piezo the extra power will be small.
Because my background is in power supplies, I would have put the parts after the full wave bridge and before Crect. (like in PFC).
Sorry I can not help. I need to get back to a paying circuit. (real job)
