How to improve stability of TIA without compromising pulse respons?
BIjoy_3000
Joined Sep 19, 2024
9
I am new to Circuit design. Recently, I tried to build a TIA with OPA355 for a Photodiode (figure added). According to a paper, Peaking in AC frequency response shows Instability. To solve this, I used the Resistor isolation method(Riso). Peaking is now reduced, but the pulse response is changed, which also affects the input signal (signal after photodiode). How to solve this?Screenshot 2024-09-08 at 11.15.41.png
figure1: TIA Circuit diagram before Rios
fig 2: Freq. response
Fig3: Pulse. Res before Rios at 100KHz
Fig4: Circuit after adding Rios
fig5: freq res after Rios
fig6: pulse response after Rios
BIjoy_3000
Joined Sep 19, 2024
9
If that's an LTspice sim, post the .asc file.
The circuit shown in Figure 1 is indeed from LTSpice, but the frequency response shown here is from an actual experiment. This bump in frequency response is not visible in LTSpice. I only added the first figure to show my circuit design.
38,932
You figure 4 schematic is different than your figure 1 schematic so we seem to be comparing two different circuits.
For example there is no R2 in the figure 4 circuit.
And I don't understand the Rios circuit.
Is this Cload a capacitance you added?
That makes no sense.
And 18+15 ohms is too low a load resistance for the op amp.
What you are seeing is likely from stray capacitance at the inverting input.
Try removing the Rios circuit and increasing the value of the 1.8pF feedback capacitor to compensate.
Likely something in the tens of pF should work.
You would need to experiment to find the optimum value.
