How to get patent and IP
RamaD
Joined Dec 4, 2009
328
It´s simple. You make an appointment, bring in your device, they test it, it fails, you pay a lot of money. Repeat that 3-5 times,then finally you might succeed.
Or you can buy the norm that is related to this, read it, make the necessary tests by yourself, and then bring it to the test center only when you are sure it is ok.
Slight change! Whether it fails or passes, you pay a lot of money!
RamaD
Joined Dec 4, 2009
328
Thanks for worthy information, can you please tell how to get these certificates?
This rating is for the degree of protection against dust and water ingress, higher the no. meaning higher level of protection. Depending on what is required for your product, the product needs to be designed. And, Kubeek has put it very nicely!
