How to get -5V and 5V from a 9V rechargeable battery
kamel2913
Joined Mar 6, 2015
43
Hi guys I'm working on a Biomedical project, in this project I need -5V, 5V and 3.3V, and I'm using two 18659 batteries connected on serial, so together they gives 8,4V when they're fully charged.
to get the 5V, I used a 7805 regulator, it worked fine, and to get the 3.3V I used another regulator and it worked, now the problem is with the -5V, I tried to generate a minus voltage with an NE555 ( it worked I get -7,5V) and then used 7905 to low it to -5, once I use 7905, the voltage drop directly to -1.5V for no reason.
I would like to know how I can fix this, and if there's another idea to slove this I will be happy to get it.
PS: I use wh-2s5a circuit to charge the batteries.
cmartinez
Joined Jan 17, 2007
8,890
Another option is to use a voltage converter, such as the ICL7660S, or the LTC1046. It's rather easy to configure it as a -5V source from 5V. It's only drawback is that it can only supply a limited amount of current.
upload_2017-4-4_19-54-45.png​
WBahn
Joined Mar 31, 2012
33,348
The basic problem with your approach is that a charge pump circuit can only supply so much current -- and generally not a great deal unless they are design with significant care. So while you 555 timer-based charge pumps works, it can't supply much current. You should be able to estimate how much average current it can supply to a load. We can't, because you haven't shown the circuit you tried.
The other suggestions -- the ones that use chips specifically design to be DC-DC converters, are a much better option.
-live wire-
Joined Dec 22, 2017
959
+/- 5V and 3.3V. Sounds awfully familiar. Oh, wait, that's the Arduino Uno output. If your appliances don't draw too much current, you can just use an Arduino Uno. Plus you can generate PWM and do coding stuff.
