How to get 3.3V from a 5V wallwart PSU...? Please... :)
R!f@@
Joined Apr 2, 2009
10,014
I guess we had to find out the "why" the hard way.
@Alec_t can you run a simulation using Regulated 5VDC feeding the battery via one diode like you did in post #49
WBahn
Joined Mar 31, 2012
33,316
I don't think simulating a NiCd battery as a constant voltage source reveals the critical information.
http://www.powerstream.com/NiCd.htm
Unlike some other chemistries, NiCd batteries can't be floated with a voltage, but rather the current must be controlled. The float current is quite low, about C/20.
Hi All
I have a rechargeable hand held Black & Decker screwdriver that I can't locate the power supply for. On the item itself it says it is a 3.3V device, and it charges by sitting within a charging unit via connectors on its side. Clever little thing it is!
So, I don't have any 3.3V power supplies, but plenty of 5V ones. What would experts advise I do to reduce the 5V to 3.3V from one of these PSU's please?
Tomorrows project :)
Some times in my circuits i need to take 3.3 voltage from 5 voltage.in order to do the same what i do is just add two zener in series with the positive side of the 5 voltage supply .actuly any zener in forward bias mode drop .7 volts.2*.7=1.4,5-1.4=3.6,
If need be add one more .
Remember this is for small current and for tech savy guys,
You can experiment the risk involves are your zener go burnt,
3.6 could be bit over
In case of 3 zener 5-3*.7=2.9 is little low
You can try
All d best
