How to generate -3.3V and -5.2V from either 12V, -12V or +5V
matthej
Joined Oct 10, 2020
68
I need to generate -3.3V and -5.2V on my board. Power for -3.3V is 1.4W and -5.2V is 9.3W.
I have + 12V, -12V and +5V coming from the power board.
I am unfamiliar with generating these negative voltages. Does anyone have an idea on how to do this?
Inverting buck-boost converter?
Thanks!
dl324
Joined Mar 30, 2015
18,524
You could use inverting regulators from your positive supplies or linear regulators from your -12V supply (if it has sufficient capacity).
My go to for switching regulators is MC34063A. They're readily salvaged from a lot of devices.
38,952
The switching regulators would be a lot more efficient.
Linear regulators would dissipate 3.7W to generate -3.3V, and 12.2W to generate -5.2V from the -12V for your power requirements.
If you don't want to roll your own, you could likely buy some inexpensive modules from Amazon or Ebay.
