I have never format computer to drive O.S. IN IT.
please tell for window 7 and XP
You're Microsoft tech support, aren't you?
- Turn on your computer so that Windows starts normally, insert the Windows 7 installation disc and then shut down your computer.
- Restart your computer.
- Press any key when prompted, and then follow the instructions that appear.
I use windows os . many time I have formatted my pcYou're Microsoft tech support, aren't you?
Ok. I just noticed you were from India, and the last time I called MSTS, one of your countrymen told me exactly the same thing.I use windows os . many time I have formatted my pc
Formatting applies to some forms of data storage. A PC is a conglomeration of components; most of which can't be "formatted".I use windows os . many time I have formatted my pc
When my W10 upgrade on top of W7 went tits-up, it wouldn't repair and refused to do a clean install either.
Actually, there are few things in life easier. Really.Deleting the Mint partitions was even more fun
I used the first thing that worked - and Acronis mount disk wasn't the first thing I tried.................Actually, there are few things in life easier. Really.
All I can find on that search is gaming software.I still use an old DOS program I found some time ago called "Overkill". When ran from a boot CD it will return any hard drive to an as-shipped state ready to partition and format. Just don't try to run it off a boot USB drive, it will kill the USB drive, also make sure only 1 hard drive is installed in the computer.
Give me a little time to decide the best way to get you the files and I will make it easy for you. In the interim search for and download Magic ISO.All I can find on that search is gaming software.
As I put the OS on one HDD and everything else on another - that would be perfect for me.
Its a long time since I played with any DOS utils - how do you make a DOS boot CD?
Can't see the wood for the trees on the UBCD download site.Give me a little time to decide the best way to get you the files and I will make it easy for you. In the interim search for and download Magic ISO.
Better yet, download and make yourself a boot cd from this web site.
http://www.ultimatebootcd.com/
It will have hard drive utilities that will get you where you need plus several other useful utilities for Windows.
I buy allot of computers for Kiosks and have to change the OS to Windows embedded. Booting to a DOS CD and running overkill is allot faster than using the UBCD but it is dangerous.
I use Dos 7.1 .ISO for that, I think it is still available out there, it has extra features such as unlimited file name length etc, It is not sanctioned by Windows, but I believe ripped from Win 98/XP.As I put the OS on one HDD and everything else on another - that would be perfect for me.
