A clock shows the time as 12.20. What is the angle the hour hand makes with the minutes hand?
The hour hand goes 360 degrees in 12 hours => 30 degrees /hour => 10 degrees in 20 minutes.When the hour hand makes a 30 degrees move in an hour, it will make a move of 10 degrees in 20 minutes.
How?
There is total 360 if anything go circle/round ...
the answer is 110 degree why?
How?That is a good start, but now draw it with the hour hand in the correct place...
Look at a real analogue clock and see where the hands are at 12:20. Think about why the hands are where they are. Draw what you see and then work out the angle between hands.How?
by Don Wilcher
