In 60min the hour take movement of 30degreeDraw the analogue clock on a sheet of paper, but instead of the 12 hours, mark the 12 divisions in degrees, starting with 0 degrees at the top.
The answer should become obvious if you remember to think carefully.
Hint - the hour hand does not point to 0 degrees
Over to you....
So how many degrees will the hour hand move in 20 Minutes?In 60min the hour take movement of 30degree
Go figure it out yourself. This is an EASY problem, and there is no excuse for your needing help solving it.A clock strikes once at 1 o’clock, twice at 2 o’clock, thrice at 3 o’clock and so on. How many times will it strike in 24 hours?
ok i got itA clock strikes once at 1 o’clock, twice at 2 o’clock, thrice at 3 o’clock and so on. How many times will it strike in 24 hours?
No, you don't need to raise the numbers to any power. The answer is a sum: 1 + 2 + 3 + ...22 + 23 + 24. You can use this formula:ok i got it
1+2^2+3^3+4^4+5^5...........................24^24
is there any formula for it?
How did you get this number?the answer is 156
How did you see the answer? 156 is wrong!I have seen the answer because solving is not getting answer.
1+2+3+4+5+6......24How did you see the answer? 156 is wrong!
