How to do active clamping?
MrAl
Joined Jun 17, 2014
13,810
I think the two resistors and one capacitor circuit would work with any supply voltage as long as the supply voltage is as stable as needed for the measurements. If it varies by 5 percent for example then that might be too much.
If the supply voltage is not 3.3v then just use two different values resistors to develop the offset voltage.
Something else to think about is the time delay before the first measurement can be made after power up. The time constant of the circuit would be RT*C where RT is the parallel combination of the two resistors, and because C might be larger then the time delay might be longer. Five time constants is usually enough for settling to within about 1 percent of the final value, but in some ADC applications it may have to be seven time constants for a settling time to within about 0.1 percent of the final value.
