panic mode
- Joined Oct 10, 2011
- 5,479
that switch could also be a transistor. when triggered by clean signal it is completely bounceless.
Oh ok that helps to explain it. If I get a chance I'll try that myself. Thanks Erichi Al,
In Dankos circuit he is using the 1meg resistor to give an initial charge to the capacitor ie: 5V, [which takes a little time to fully charge]
then he closes the switch which shorts across the capacitor and the inductor and of course it forms a decaying oscillatory loop.
In my sim I set the capacitor charge IC=5V then I close the discharge switch path.
E
Hi there,"Secret" of that physical circuit is in bounceless switch,
which is two crossed freshly stripped copper wires.
Between wires is gap about 1 mm.
I fast an firmly press on cross-point by fingertip and test is done.
Soft tissue of finger effectively damping wires vibration and prevent break of contact.
That's it.
When I use tumbler switch, I have oscillogram with frequency 360.75 kHz (coil self-resonance) instead 7.65 kHz:
Hi Al,.The thing is, are you supplying any energy to the cap or inductor before you open the 'switch' ?
Oh ok great, I'll look into that scenario. Thanks again.Hi Al,.
As I have posted earlier and Danko accepts, he allows sufficient time to charge the Cap from the 5V supply via that 1meg resistor, then he closes the discharge switch.
Which results in a oscillatory discharge response.
E
Hi Eric,hi Al,
This shows the Cap charge time const, approx 1mSec, so have allowed 5 times that constant to assume fully charged.
The sim plot shows the charge/discharge waveforms, the 2nd image is a time expanded image.
E
Note:
The .IC has been regraded as a Comment, also 10V chosen in order to make Ctau more obvious.
View attachment 335946View attachment 335947
Hi Eric,Hi Al,
Yes precharge the cap.
E
| Thread starter | Similar threads | Forum | Replies | Date |
| Y | exctracting loop inductance from S-parameters | PCB Layout , EDA & Simulations | 0 | |
| M | Inductance values versus voltage? | Analog & Mixed-Signal Design | 3 |
