Is there any way to identify which finger I have used while hitting a drum? I had thought of using fingerprint sensor but it's slow for my application. I need it to be as fast as recognising in 20-40 ms. And it needs to be sensitive too
Are you willing to paint your fingers different colors for easy recognition? If not, nothing else comes to mind!Is there any way to identify which finger I have used while hitting a drum? I had thought of using fingerprint sensor but it's slow for my application. I need it to be as fast as recognising in 20-40 ms. And it needs to be sensitive too
I had thought of gloves earlier but my professor was against it. We're trying to make an electronic version of Indian classical musical instrument called mridangam and we want the player to have a natural feel about it while playing.Raymond beats me to it.
I was going to say wear a glove that has elastomeric resistive or capacitive sensors at the finger tips.
I'm trying to make an electronic version of an Indian percussion instrument called mridangam. The problem is, there are two notes which are played on the same spot, one with little finger and the other one with index finger. The sounds produced are different in the actual instrument. I had tried taking a pvc disc and hit it the same way I hit on actual instrument hoping the frequencies of vibration will be different.. But the accuracy was only 70-80 percent. It has to be close to 100 percent. So, if I can find out which finger I'm using, that can helpAre you willing to paint your fingers different colors for easy recognition? If not, nothing else comes to mind!
What are you trying to accomplish with the recognition of different fingers? Presumably there's some higher goal, and finger identification is an intermediate step. Maybe there's a more effective solution to your higher goal that won't require finger ID.
Well, that might increase the task difficulty a bit. Color sensors have already been mentioned. What about accelerometers mounted above the metacarpals. The finger tips and much of the finger could remain pristine. Of course that is not a simple program to write.I had thought of gloves earlier but my professor was against it. We're trying to make an electronic version of Indian classical musical instrument called mridangam and we want the player to have a natural feel about it while playing.
See that disc like structure, I'm striking my fingers on that. It's made of PvcWhat are you using to tap fingers on? Have you a picture?
Yes, that's the instrument which we are trying to emulateLike this:
If I were you, I'd focus on what's different about those fingers, and how that translates into tone/timbre changes. Is one finger skinny and hard, and the other big and meaty? Does one naturally have a tendency to bounce away from the head more quickly, allowing it to resonate longer, while the other inadvertently lingers a bit, muting the head more quickly? Is one naturally hitting with the pad/fingerprint area while the other hits more with the end of the finger? There must be a reason it sounds different, and l wouldn't be at all surprised if it was based on technique as much as it is on any physical characteristic of the fingers.I'm trying to make an electronic version of an Indian percussion instrument called mridangam. The problem is, there are two notes which are played on the same spot, one with little finger and the other one with index finger. The sounds produced are different in the actual instrument. I had tried taking a pvc disc and hit it the same way I hit on actual instrument hoping the frequencies of vibration will be different.. But the accuracy was only 70-80 percent. It has to be close to 100 percent. So, if I can find out which finger I'm using, that can help
you mean use ML?The only feasible thing I can think of.....and I could not do......is modify a speech recognition program. Might not even have to modify it......I'm sure they are better at it now.
Just teach it your "hand"......and go to town.
Are you allowed to use software?
