Circuit to detect underground power ie 50HZ AC at a depth off 500mm no power is been drawn but cable is active
If the soil is moist, there will be almost no electric field.If it is possible to connect both , or all, of the conductors together to the source of the 50 hz power, then it should be possible to probe the general area where the cable is buried and to sense the electric field produced by the voltage in the cable. The field should be strongest in close proximity to the cable.
If the connection to the different conductors is not changed, the field will be much weaker, but the same scheme should work.
This is likely. The author of the topic should clarifyIt may be that this cable has failed open, in which case that is not possible. We do not have any details.
We need a lot more info to provide more than approximations.Circuit to detect underground power ie 50HZ AC at a depth off 500mm no power is been drawn but cable is active
Interesting device. How deep can it detect a cable in a wall? Is there a difference in sensitivity when the cable is energized and when it is not? Do nearby live cables have a significant effect on sensitivity?I own a "wire tracer" package that uses the scheme described in option "D", and it does provide an impressive amount of sensitivity. It is called "Fox and Hound", and made by the TRIPLLET company. It is marketed as a LIVE WIRE tracer, although it works just as well for non-powered wires. I have not used it for under ground tracing, but certainly the principle is quite valid. So that could be an option to explore.
Signal injector tools.Interesting device. How deep can it detect a cable in a wall? Is there a difference in sensitivity when the cable is energized and when it is not? Do nearby live cables have a significant effect on sensitivity?
