MisterBill2
- Joined Jan 23, 2018
- 28,651
Certainly a good question: Looking back at post #1, the TS is asking for a tracking device to sense thos signals in the car'swiring. THAT is totally different, isn't it?? Not to add a tracking device, BUT to track the wires!
In that case the TS CERTAINLY needs to understand a bit about automotive electrical systems. For the "ignition signal", starting by looking at and "back probing" the wires from the ignition switch! With the key off and out, at most two will be live. With the key in, and turned to the "ACCESSORY" position, the IGNITION and START wires will not be live, but all the others should be. Switching to the "RUN" position will switch on the "IGNITION" wire power.
The seatbelt wires will be more complicated because they communicate with the seatbelt reminder system. BUT once again, back pprobing the connectors under the seats should reveal which are the feed wires and which are the switched signal wires.
