How to Detect 12V-14v Ignition Signal Without Cutting Wires? (Non-Contact Method?)
28,612
Certainly a good question: Looking back at post #1, the TS is asking for a tracking device to sense thos signals in the car'swiring. THAT is totally different, isn't it?? Not to add a tracking device, BUT to track the wires!
In that case the TS CERTAINLY needs to understand a bit about automotive electrical systems. For the "ignition signal", starting by looking at and "back probing" the wires from the ignition switch! With the key off and out, at most two will be live. With the key in, and turned to the "ACCESSORY" position, the IGNITION and START wires will not be live, but all the others should be. Switching to the "RUN" position will switch on the "IGNITION" wire power.
The seatbelt wires will be more complicated because they communicate with the seatbelt reminder system. BUT once again, back pprobing the connectors under the seats should reveal which are the feed wires and which are the switched signal wires.
Mussawar
Joined Oct 17, 2011
158
Hi Anas,
Since you didn't clearly mentioned the purpose of your project, it becomes a bit more complex and harder to get specific solution.
As far I understand, you want to detect whether the vehicle engine is running AND someone has fasten a seat belt; and if yes, you want to activate your tracking device. For me, It is seems an anti-theft system. right?
IF this is the scenario, why ignition signal detection is necessary BTW?
A lot of other methods can be used to detect this situation. Ignition switch ON, wheels rotation, wind speed, engine temperature, steering movement, vehicle's vibration, PIR sensor and a lot more.
For connections, "back probing" is very good option as mentioned by @MisterBill2 .
Please make the purpose more clear if possible so you can get clear answers.
Good luck.
