I wanted to build a circuit which would produce a set of signals of different frequencies in different channels simultaneously using a single reference source. I also want the frequencies to be changeable. I am looking to generate frequencies in kHz and MHz range. On searching on the web I came across PLL. I wanted to know if I can do it using PLL or any other methods. It should be fully analog.
