I thought the supplies were ±1.8V and the signal was ±1.0V. At least that is what the signal graph seemed to imply.You will need two power supplies, one at least 2V plus and one at least 2V minus to power the op amp.
Do you have that?
so I thought that meant the signal was up to 1.8V peak.it has to be working from -1.8V to 1.8V range at least.
He did include a diagram that shows a triangle waveform going from -1V to +1V. There is no problem making the waveform go ±1.8V as long as the opamp supply has sufficient head room to allow the output to make it all the way there, which would be the case with some headroom, if the supply voltages were ±2V as you suggested.Well the TS stated:so I thought that meant the signal was up to 1.8V peak.
