How to convert positive number to negative number in Two's complement code?
Osvaldon
Joined Sep 24, 2016
5
I have two numbers in Two's complement code A and B, where both of them are positive.
I need to subtract B from A ( A - B).
How can I do this when I can do the following:
Perform shifts, invert, +1, -1, SUM, XOR.
I think I should convert B from a positive number to a negative and them sum A and B, but I got not idea how to do that.
Osvaldon
Joined Sep 24, 2016
5
Welcome to AAC!
Is this homework?
Hello, yes it is. I'm supposed to create a micro command for the CPU (or something like that) that would do the following A - B / C^2. I got division and multiplication covered, but I got no idea how to convert B to a negative number so I could A + B, so I'm basically stuck because of it.
Osvaldon
Joined Sep 24, 2016
5
What is the relationship between a number and it's two's complement?
Do you mean how to transform a number into two's complement? I think it's inversion then +1 and you got a number in it's two's complement.
What if I were to subtract 1 from B, then do a logical shift left and then right and finally add +1 again, would that work?
dl324
Joined Mar 30, 2015
18,465
What is the relationship between a number and it's two's complement? For example 3 and it's two's complement.
This is homework. You tell me.
33,184
You are making a common mistake in your thinking. You do not do this to transform a number into two's complement -- you do this to find the representation of that number's complement (i.e., it's additive inverse) as represented in two's complement. This is conceptually a very different thing.
If I have a value, A, and I have the representation of that value in two's complement, then inverting all the bits and adding one gets me the two's complement representation of -A; and it doesn't matter whether A is positive or negative.
33,184
But why do you need to do A + B at all?
Your equation has you finding the square of C. Then dividing B by the square of C. Then subtracting the result of B divided by the square of C from A.
Perhaps you need to review order of operations?
33,184
So what you are saying is that you think you should perform
A + (-B)
Sounds reasonable.
So how do you take the negative of a two's complement number?
Osvaldon
Joined Sep 24, 2016
5
My mistake. It's (A - B) / C^2 not A - B / C^2
A + (-B)
Sounds reasonable.
Invert B and add one?
So if I take a binary number, invert it and add one, I get it's represantation in two's complement, then if I repeat the same action I get a represantation of that same, but negative number in two's complement?
35,171
No.
Two's complement is a number representation, it is a system for representing positive and negative integer values.
If you have a positive number, its two's complement will be the representation of the negative value.
Forming the twos complement of a negative number will give you the positive value.
33,184
No. If you invert it and add one, you get the representation of the additive inverse of that number. If you invert it and add one again, you get the original representation back.
If you have a positive number, then the binary representation of that number is the same either as an unsigned binary representation or as a two's complement representation.
Osvaldon
Joined Sep 24, 2016
5
No.
Ok thanks, that's what I needed.
Free likes for everyone!
