How to convert DOUBLE to char*??
HappyC4mper
Joined Oct 13, 2017
71
C++:
#include <mbed.h>
#include <stdio.h>
int main()
    double Test1 = 1.234;
    char* Test1_s = "DIDNT WORK";
    Serial PC(USBTX, USBRX);
    while(1)
        //Convert Test1 to Test1_s
        PC.printf("%s\n", Test1_s);
        while(1);
Hey guys,
I have a slight problem which I cannot figure out. How do I convert 'Test1' to 'Test1_s'. Im using mbed
dl324
Joined Mar 30, 2015
18,453
Don't understand your question. Are you trying to print a double as a string?
sprintf or printf will do it, but some IDE's don't support floating point conversions so you have to use workarounds. Also, including sprintf in your executable is expensive. That's why some IDE's leave out support for floating point.
35,079
Test1 is double.
Test1_s is pointer, as you already know.
Why would you want to do this?
Do you mean something like this?
Test1_s = num2str(Test1);
Why not just
pc.printf("%d\r\n", Test1);
HappyC4mper
Joined Oct 13, 2017
71
Test1 is double.
Why not just
So i have a command prompt to see if it works or not.
how to make Test1_s (which is a char*) become the value of Test1 (which is a double (1.234)). Ignore "didn't work"
Basically, I want test_1 which is 1.234 to show up on test. If it doesn't work, it would show up as ''Didn't work''. But if the conversion worked, test1 should show up as 1.234.
