Here is the assignment paper screenshot, sorry for the poor quality, it's captured with a crappy front webcam of my laptop.Are you sure that's the question?
There are only 19 binary digits.
BCD would imply some multiple of four for the total number of bits
Thank you, I already knew that, I believe the question is wrong in my assignment paper, it should be 20bits or 16bits not 19 bits long (1 decimal number is represented in 4 bits so).
The big problem is that the BCD code is the decimal show in binary format, so only can be show 0~9, any number over 9 is wrong, so discussing a long strings just doing the same problem the number was limited in 0~9.Thank you, I already knew that, I believe the question is wrong in my assignment paper, it should be 20bits or 16bits not 19 bits long (1 decimal number is represented in 4 bits so).
That's hilarious XDThen, I propose the best answer is that
\((0111 1001 0010 0010 110) _{BCD} = Nothing in _{Decimal}\)...
lol, I watched almost every video on youtube about BCD and read many articles and notes and stuff related to BCD thinking that I was doing something wrong.His teacher may cry for his fault and then maybe he need to send the score to the students or do some homework before he give another homework to the students.
If they should have asked like "Can this number be converted into decimal?" or "is this a valid BCD number?" it would be much betterMaybe the teacher is expecting them to catch that particular error.
I recall a teacher dropping a space in an Excel's cell. Some few students were smart enough to discover why their work did not produce the expected results.
OkayI agree that the problem has an error in it. The best you can do is to indicate that the BCD representation is invalid, just like if you were asked to convert 12P4 from decimal to binary. There IS no reasonable solution. Since you know that the answer is supposed to be 3916, you can show what that would be in BCD and show that the error appears to be the insertion of 1100 into the BCD representation.
Don't worry too much about the missing leading 0. That's not much of an issue and it might actually be the case in hardware. For instance, many instruments have a display for which the leftmost digit can only take on values 0, 1, 2, and 3. If those instruments stored values in BCD, the first two bits of that leftmost digit might not be stored at all, but simply be inferred as zero.
