How to convert BCD to Decimal?
Doraemon
Joined May 21, 2015
13
Converting Decimal to BCD is easy but how do I convert BCD to Decimal when the BCD is like this:
0111100100100010110 (BCD) = 0011 1100 1001 0001 0110 (grouping into 4 bits from right to left)
= 3 12 9 1 6 (converted 4bits binary to decimal)
= 312916 (Final decimal number)
As you can see I've done as per the method but the answer is wrong (tested on online converter), anyone can help me with this? I'll really appreciate it, I googled and found almost all articles about Decimal to Binary. I've no idea what I'm doing wrong.
ScottWang
Joined Aug 23, 2012
7,505
Maybe you could pick up the Magical treasures from your pocket and to check the time after the answer you know ... :D
Try to using the hexadecimal to show them and converting to decimal.
Doraemon
Joined May 21, 2015
13
I'm writing my assignment since last 7 hours continuously and came across this problem, I'm completely exhausted right now I have 2 days left to submit my assignment XD, Just asked here if someone can provide a solution and save my time.
"Try to using the hexadecimal to show them and converting to decimal."
I don't understand what exactly you're suggesting to do, should I convert those grouped 4 bits to hexadecimal and then convert the hexadecimal to decimal?
Doraemon
Joined May 21, 2015
13
Update: I checked the answer is 3916 but what happens to "12"? Should we ignore the digits larger than 9? I checked the BCD and Decimal table and 12 is represented as 00010010 which is 1 (0001) and 2 (0010) together = 12 (00010010). Any help will be appreciated, I'm really confused right now :(
Update 2: Found this on one website:
Invalid BCD Numbers
These binary numbers are not allowed in the BCD code: 1010, 1011, 1100, 1101, 1110, 1111
So I guess I need to ignore the 1100. And in exam I need to write it like this:
0111100100100010110 = 0011(base2) 1100(base2) 1001(base2) 0001(base2) 0110(base2)
= 3(base10) 9(base10) 1(base10) 6(base10)
= 3916 (base10)
Am I correct? :)
ScottWang
Joined Aug 23, 2012
7,505
How come you missing the "12"?
You don't know this - Try to using the hexadecimal to show them and converting to decimal.
I think you need to restudy the hexadecimal if you not study yet.
Try to answer the hexadecimal to decimal as :
Code:
Hex → Dec
01  →
06  →
09  →
0a  →
0d  →
0f  →
   Hex  →  Dec
(01+01) →
(09+09) →
(0f+0f) →
Using the "[" + "code" + "]" "[" + "/" + "code" + "]" function to show the math.
If you don't know hexadecimal, then google it.
djsfantasi
Joined Apr 11, 2010
9,237
I fail to see how converting to hexadecimal will help. There are 4 bits which are not a BCD value, whether in binary or hexadecimal. 1100 in binary is the same value as 0C in hex. No matter which way you write it, it's not representative of a decimal digit (BCD).
Unfortunately, the problem doesn't state what to do with an invalid value. So it's unclear whether you're correct or not.
ScottWang
Joined Aug 23, 2012
7,505
You break the balloon as exposing the new clothes of King.
Doraemon
Joined May 21, 2015
13
Code:
Hex → Dec
01  →
06  →
09  →
0a  →
0d  →
0f  →
   Hex  →  Dec
(01+01) →
(09+09) →
(0f+0f) →
Okay I think I'm familiar with Hexadecimal, I just started learning 3 days ago. Here is the answers:
Code:
Hex → Dec
01  → 0 * 16^1   +  1 * 16 ^0  =  1
06  → 0 * 16^1  +  6 * 16 ^0  =  6
09  → 0 * 16^1  +  9 * 16 ^0  =  9
0a  → 0 * 16^1  +  a * 16 ^0  =   10 * 16 ^0 = 10
0d  → 0 * 16^1  +  d * 16 ^0  = 13 * 16^0  =  13
0f  → 0 * 16^1  +  f * 16 ^0   =  15 * 16^0  = 15
   Hex  →  Dec
(01+01) → 1 + 1 = 2
(09+09) → 9 + 9 = 18
(0f+0f) →15 + 15 = 30
Doraemon
Joined May 21, 2015
13
That's what I'm trying to figure out what to do with 12 aka 1100 in binary! :confused:
I belive ScottWang has the answer but he is trying to teach me something I should have known before solving this problem.
35,125
What is the difference between the binary representation of a decimal number and the binary representation of a value in BCD?
Doraemon
Joined May 21, 2015
13
Binary representation of decimal number 12 in binary will be 1100
While 12 will be denoted as 00010010 in BCD, the numbers after 9, which are 2 digits are represented differently. Each digit will be represented in 4 bits, total 8 bits.
35,125
Your original question ought to be:
How to convert from binary to BCD?
along with
How to convert from BCD to binary?
Show us how you convert from BCD to binary.
Note that BCD means binary coded decimal. Which means that it is both binary and decimal at the same time. It is a binary representation of a decimal value.
0 = 0000
1 = 0001
2 = 0010
3 = 0011
4 = 0100
5 = 0101
6 = 0110
7 = 0111
8 = 1000
9 = 1001
There are no values greater than 9.
35,125
Make a distinction between the value of a quantity and its representation.
The quantity twelve can be represented in many ways:
binary: 1100
hexadecimal: 0C
decimal: 12
BCD: 0001 0010
Doraemon
Joined May 21, 2015
13
along with
0 = 0000
1 = 0001
2 = 0010
3 = 0011
4 = 0100
5 = 0101
6 = 0110
7 = 0111
8 = 1000
9 = 1001
Okay I'll appreciate it if you can tell me step by step solution of
0111100100100010110 (BCD) = ?(10)
The (BCD) and (10) both are written in small letter in subscript (in base).
That's my question written in my assignment paper :)
"Show us how you convert from BCD to binary."
To convert BCD to binary, first I need to convert BCD into decimal and then convert the decimal into binary as far as I know. But the question is what steps should I take to convert BCD into decimal.
