panic mode
- Joined Oct 10, 2011
- 5,420
Might want to wait until you find a suitable solenoid before ordering the parts as the circuit might need to be modified.I have not purchased the 12VDC latching solenoid yet.
Any luck finding that solenoid?I have not purchased the 12VDC latching solenoid yet.
Not true, see post #18.and since any scheme to provide pulses is fairly complex, it seems to me that the TS will need to reconsider the concept.
OK, for that scheme in post #18, a polarity sensing solenoid.What double solenoid?
I think you're overlooking some important issues: In your system a momentary pulse latches or unlatches the gate. I'll ask this question again (below)To the same degree as a locked house door. I copied this from a google search. "A latching solenoid control circuit uses brief (20–50ms) voltage pulses to toggle between states, reversing polarity to switch between locked and unlocked. It requires an H-bridge or DPDT relay setup to manage current direction, providing high efficiency by eliminating continuous power consumption." I am looking for someone to translate that sentence into a wire diagram that I can make.
Putting it a different way - what if you have to escape through a window and can't get to the gate switch? How do you get through the gate in such an emergency?Quick additional question: What happens in an emergency when you need to escape - get through the gate in a hurry?
In that case I believe using a linear actuator operating a bolt latch will work.Been looking but can't find a latching solenoid.
