Thanks,The modilator is going to produce some signal with a carrier frequency and a modulation form some source. It will have excursions above and below ground, which makes it unsuited to act as a drive sognal for the digital hex inverter.
To echo Thingmaker3, what are you trying to do???
Oh Thanks Sir,A digital driver will cause you to lose your modulation information, even if you could get the correct input voltage levels. You need op amps. See below.
You probably won't like the choice of op amp, but you need one that can drive a capacitive load with high output current.
CAVEAT: I have not tested this circuit, or even simulated it.
I thought perhaps it is Single ended orginally. I used an onpamp with virtually grounded circuitry but the output signal was not the simallar as the output of the modulator.Op amps do not necessarily need dual supplies. As you can see, the circuit I drew has only one.
You might be able to use a different op amp, but you should probably put 100 ohms in series with the transducer in order to isolate the capacitive load of the transducer from the op amps. LM8272 is specially designed to be able to drive capacitive loads.
A discrete transistor driver would be complex. If you want a bridge driver, both transistor amplifiers would need to be push-pull.
What kind of transistors did you use? And how were they connected? (What type of bias, et.al.?)
What value did you use for Rf?Ron, the opamp circuit you have designed is working thanks for it, but the output amplitude is low, how to get a higher amplification?
Sorry I am an
amateur in electronics field.
as I am using on the shelf transducers so the carrier freq is 40kHz.What value did you use for Rf?
What is the carrier frequency in your modulator?
I ran a sim, and it works, but before I post results, tell us:as I am using on the shelf transducers so the carrier freq is 40kHz.
Rf is between 100k to 330k but the amplitude is abit higher with 330k.
by the why there is not senseable difference in the output using a 100ohm resistor for the transducer.
Can you simulate the circuit and see if it is possible to imporveits output?
thanks
1. It is between 2 to 5kHz, why this factor is important?I ran a sim, and it works, but before I post results, tell us:
1. What is the frequency range of your modulating signal?
2. What is the source impedance of your modulating signal and your carrier signal?
3. Do you have a part number for the transducer, or better yet, a datasheet?
If it were low (such as 100Hz), the input RC would roll off the frequency response.1. It is between 2 to 5kHz, why this factor is important?
It is important, because your input impedances to the modulator are 100 ohms and 51 ohms, respectively. They may load your sources, severely attenuating the voltages. You either need low impedance sources, or we need to change the values of these resistors. What circuits do these signals come from?2.I don't know how to calculate it!
I tried to model the transducer as best I could. The equivalent circuit is on the attached schematic.3.See the files.
I think TL072 will be fine. The impedance of the transducer at resonance is high enough that 100 ohms in series will not reduce the output power significantly.Do you know another brands for those capacitive opamps? I want to see If I can find another mark..
Thanks.
Thanks 'Ron H'If it were low (such as 100Hz), the input RC would roll off the frequency response.
Note the voltage levels on the modulator and carrier voltage sources in my schematic. These are maximum peak voltages (from zero to peak). The maximum carrier level can be higher (0.5v peak?) if you don't mind having lots of carrier harmonics delivered to the transducer (it probably won't hurt anything). If you exceed the modulating input level, you will get lots of distortion in the modulation.
I hope you realize this is a balanced modulator with suppressed carrier output. It is not an amplitude modulator, although it could be modified if necessary.
