You need to understand that there will be (approximately) zero AC (signal) voltage at the outputs of the modulator, since they are connected to the summing nodes (virtual AC grounds) of the op amps. If you don't understand why this is the case, perhaps one of the moderators can point you to a tutorial on op amps. If you want more output from the op amps, increase the resistors Rf (12k in my schematic). Higher supply voltage will help, but you will still have to increase Rf.Oh, Ron H, I forgot to say that I have distortion at the output of TL072 when I increase the modulating amplitude or reduce the resistor between pin 2 and 3, so can you direct me or show me a circuit (probably based on transistors) to incrase the amplitude ofthe output of the modulator before TL072 and then reduce the volume of modulating signal or increase the Resistor? Is it possible at all?
The schematic and waveform files were the full width of my screen when I posted them. This forum always seems to shrink pictures, and I have no idea how to make them larger. When I post on the Electro-Tech forum, they come out full size. Apparently, shrinking them saves server space, but it also makes them unreadable in some cases. Can one of the moderators or administrators comment on this?
