How to connect LED Directly to 220V
bertus
Joined Apr 5, 2008
22,981
Use a wallwart to lower the voltage and then calculate the resistor for the led from the outputr voltage of the wallwart.
PS The ToS does not allow leds to be connected directly to the mains
pwdixon
Joined Oct 11, 2012
488
If you were to try this directly the inline resistor would need to be very high power capacity to dump the waste power and it would be very inefficient. And that's apart from the obvious danger of mains wiring itself.
mcgyvr
Joined Oct 15, 2009
5,394
The LED will be 1.9 to 3.5 V RED blue white 20mA 5mm
You say "the" LED then call out 3 colors and a wide Vf range?
Are you just using 1 or 2 or 3 LEDs?
Please post a schematic of how you intend to connect the LEDs?
Are they in a series string? Or 3 in parallel or what?
You must provide this information or we cannot tell you how to size the resistor.
bertus
Joined Apr 5, 2008
22,981
Did you see the first reply?
I mentioned a wallwart over there for isolation.
A phone charger might also work.(5 Volts USB).
