How to connect 2 pin led strip to 4 pin controller
sghioto
Joined Dec 31, 2017
8,765
Hold on a minute. The black controller you have should work with the 12 volt LED strip if you connect the 12 volt AC adaptor to its power input.
Pabas
Joined Dec 24, 2020
27
What do you mean? Negative and positive? Sorry for stupid questions I just startin with electronic. Also how to measure this if black probe to jack Hassis and red to output pins it's (startin from pin with arrow) 12v than its jumpin from 0.9 to 2.2v than 2.5v than 3v on last one.
Pabas
Joined Dec 24, 2020
27
I think I did it wron way so when I put black probe on arrow pin the last one is -500mV other way arrow pin is 500mV
sghioto
Joined Dec 31, 2017
8,765
Yes. Find the two pins where the voltage reads +12 volts.
I'm assuming the arrow pin is negative. So connect black lead of your meter to this pin and see if there is 12 volts on one of the other 3 pins.
Pabas
Joined Dec 24, 2020
27
So with black probe on arrow pin next one is jumpin can't read anything it's going from -5v to 8v, next has 1v and last has 500mV
Pabas
Joined Dec 24, 2020
27
With black probe on arrow pin none of them. It showed 12v when I put black probe on power supply jack and red on arrow pin.
Pabas
Joined Dec 24, 2020
27
Okay I plug RGB strip and changed brightness and now 3rd pin measure - 12v with black probe on arrow pin
sghioto
Joined Dec 31, 2017
8,765
Appears the WIFI may be switching the low side. Then connect the positive side of the LED strip to the arrow pin and negative to one of the other pins
Inking
Joined Mar 10, 2023
Tying the three outputs together as you have shown, is a bad idea. You might create a short and damage the wifi controller.
Why not tie the B (blue) connection to the led strip, leaving the R and G disconnected? Then you just control the strip with the B channel, ignoring the other two. Blue and white LEDs use a similar amount of color (closer than red or green LEDs)
It looks like the Wi-Fi controller is for an RGB strip. It has three channels; one for each color. Just use one.
Ok but does the dimmer function works with this way
