How to conect solar panel to 2d series battery
Erick npn
Joined Sep 25, 2017
13
Hi everybody, I’m working on a little project,
I would like to replace the 2d battery which supply pover to a motor with a rechargeable one connected to a solar panel. How I can dimension the solar panel and I guess the charger for the batteries?
The motor needs 2.4w
ericgibbs
Joined Jan 29, 2010
21,649
hi Erick,
I am assuming the 2d, are two D size 1.5V nominal batteries.? ie: it is a 3V motor requiring 2.4W/3V = ~ 0.8Amps.?
The Solar panel and battery AHr capacity will depend upon the motors required operating time period and amount of sunshine available.
E
Erick npn
Joined Sep 25, 2017
13
hi Erick,
E
Hi! Thanks for the answer!
The amps should be 0.6.
The motor has to work for 3/4 hours a day. The solar panel will be outside. Not sure for how long it can be under the sun.
Maybe to compensate the charge I’ll need a bigger battery or a charger pack as the one used for charging mobiles...
Any good advice? Thanks!
Erick npn
Joined Sep 25, 2017
13
Hi, I’m still stuck in choosing the solar Pannel, I’ll probabl use 2 rechargeable batteries D 3000mAh
Not sure how to regulate the charge from the solar panel and the right solar panel to use. I’ll very apreciete if some one will advice me.
Merry Christmas!
Bernard
Joined Aug 7, 2008
5,784
Is that 45 min. / day or 3 to 4 hours / day for motor operation ?
Seems a rechargeable D should be around 10,000 mA h ?
spinnaker
Joined Oct 29, 2009
7,830
Merry Christmas!
Morningstar makes some excellent products for a wide range of needs. Their tech support is excellent too.
https://www.morningstarcorp.com/
