The voltage for my energizer is around 100,000V and i use a 6 light neon light fence tester to test the voltage for fence and its voltage range is 10,00V-10,000V. When i use the 6 neon light fence tester to test the voltage and all the lights are full and glitter. But when i reduced the voltage to 2KV-4KV, and all the lights are dimm, Is it normally that there will be three lights should glitter right? So is there any problem for the neon light fence tester? or the fence itself?
