How to calculate the flux in the two connection wire in magnetic circuit ?
Reject123
Joined Mar 1, 2020
Please help me solve this homework, im stuck with it
I think there will be 4 reluctance in this circuit, 1 in the left wire , 2 in the top , 3 in the right wire and 4 in the bot, i dont know whether it's right or wrong , so help me please.
Jony130
Joined Feb 17, 2009
5,596
No, you have only one reluctance in this case. So try to calculate the reluctance base on the core dimensions given to you. Can you do it?
Reject123
Joined Mar 1, 2020
According to some previous topic that i have learnt , If a magnetic circuit has 1 wrapped then will have 2 reluctances which is reluctance of the iron core ( assume it is ferromagnetic core), and another one is recluctance in the wrapped, so i dont understand what your meant ? :(
Can you explain more ?
Jony130
Joined Feb 17, 2009
5,596
You understand it wrongly. In your example, you have only one path for magnetic flux to "flow". Hence only one reluctance value.
R = le/(μ*Ae)
le - Effective magnetic path length
Ae - Effective core area
μ = μo * μr
Reject123
Joined Mar 1, 2020
R = le/(μ*Ae)
μ = μo * μr
Thank you very much, I get it now :D
